Sam Colalillo
low 9's w/ a 109
- Jan 12, 2005
$49.00 (SOLD) Competition Engineering C2720 Adjustable Drag Shock
· 3 way adjustable drag shacks
· Less than 2,000 miles on them
· This is a pair of Rear shocks
![shocks2.jpg shocks2.jpg](https://turbobuick-data.community.forum/attachments/287/287376-f786d0f1fd8c43ba6e24e0995598511a.jpg)
$20.00 (SOLD) CATALYTIC CONVERTER TEST PIPE & 4-BOLT FLANGE
· replacement pipe to eliminate the catalytic converter for off road use only
· 4 bolt flange
· Never installed
![test pipe 1.jpg test pipe 1.jpg](https://turbobuick-data.community.forum/attachments/287/287377-b4e54ea6edd1869c5dd601147cbc53d8.jpg)
$30.00 RJC racing boost controller
· http://rjcracing.com/product/boost-controller/
· Has less than 2,000 miles on it
![rjc controller.jpg rjc controller.jpg](https://turbobuick-data.community.forum/attachments/287/287378-3df0192287c81406a45e17241021c875.jpg)
$25.00 (SOLD) RCJ racing Rocker shaft supports
· Brand new never installed
· http://rjcracing.com/product/rocker-shaft-supports/
![rjc braces.jpg rjc braces.jpg](https://turbobuick-data.community.forum/attachments/287/287379-9121988edd8d2ed2d5a699688fcdbebc.jpg)
$95.00 (SOLD pending payment) RJC racing Race crank pulley
· 5 lbs lighter than the stock crank pulley
· 6061-T6 aluminum
· This is not an underdrive pulley
![CRANK PULLEY 2.jpg CRANK PULLEY 2.jpg](https://turbobuick-data.community.forum/attachments/287/287380-ccefd2d688ba92df2cacb45703935ccf.jpg)
$54.00 (SOLD pending payment) RJC racing Billet water pump pulley
· This is the same diameter as the stock pulley
· 6061-T6 aluminum
![WATER PUMP PULLEY 3.jpg WATER PUMP PULLEY 3.jpg](https://turbobuick-data.community.forum/attachments/287/287381-56ad8fca8d9912ad600c70870d054c06.jpg)
$65.00 (SOLD pending payment) Belt Tensioner in good condition with RJC idler pulley
· Tensioner has under 40,00 miles on it
· Pulley is one year old
![IDLER1.jpg IDLER1.jpg](https://turbobuick-data.community.forum/attachments/287/287382-44bc759a961254a52abd9b4931fe9e4f.jpg)
$80.00 Stock aluminum alternator, air conditioning & power steering mounting bracket
· Has under 40,000 miles on it and is in great condition
![bracket.jpg bracket.jpg](https://turbobuick-data.community.forum/attachments/287/287383-315bd91668b350c5280b3e4ea46042d8.jpg)
$150.00 (SOLD) Turbo Buick valve covers
· Black wrinkle coated
· -12 AN fittings welded to each valve cover (for hoese which route to the a vent tank)
$45.00 (SOLD) Coolant reservoir & windshield washer fluid tank Carbon fiber dipped
· These are stock parts which experienced the carbon fiber dip process
$45.00 Heater hose assembly
· Has an aftermarket heater control valve
· In good condition, no leaks, needs cleaned up
· Has under 40,00 miles on it
· 4 bolt flange
· Never installed
· 6061-T6 aluminum
· 6061-T6 aluminum
![VALVE COVER 1.jpg VALVE COVER 1.jpg](https://turbobuick-data.community.forum/attachments/287/287384-e6fc01ce20ba20ef0d048305c4c00511.jpg)
![tanks1.jpg tanks1.jpg](https://turbobuick-data.community.forum/attachments/287/287385-1171e273c6ea461a689803f15bc900e3.jpg)
