Raer Springs?
Turbo-6
Hey all,
I am a new 1987 GN owner... I cut my 275/60R15's due to a leak in my air shocks... I replaced them with Billstiens, and i am still cutting down my Tire :( ... its to the point were I am going to have to replace it :( ... what opptions should I persue? place airbags in the shocks? or do i need to replace the rear coil springs? This is only on the passanger side.
Any help would be appericated!
Thanks in advance!
T
I run dual airbags with 275/60's. Use seperate fill lines to equal out the ride height for normal driving and to pre-load the right side for the strip. Full Throttle Speed & Style, Kirban Performance and Gbodyparts (among others) all carry a kit just for our cars which include everything to install including heat shields for the tail pipes. All are respected vendors of this site..
Hope this helps and congrats on the purchase of the GN - Jimmy.
I have a good set of cargo coil springs-never had a problem cutting tires-$85. Shipped
I used to run that same tire and kept it from rubbing using cargo coils and isolators top and bottom of the spring. Didnt use air bags at the time. Hope this helps.
