Random TTA/GN leftovers
flybyu
I need to get this out of my garage and attic as it is just all sitting around doing nothing when it can be used by someone who needs it. These were all from a 89 Turbo Trans Am.
TTA Owners kit in great shape missing key ring $800
25th Ann spark plug wires w/insulators $285
OEM intake with air filter box/filter $185
Stock new (non TTA part number) loaded cylinder heads $100
OEM TTA GM repair manual (Not the reproduction) 'used' $50
OEM fuel pump (used) 29k $15
Stainless steel never installed trans cooler lines..custom made $40
Rear trunk complete pull down motor assembly (used) $65
Leather T top bags (used) $50
Chrome rear diff cover w/drainplug (used) $10
2 brand new brute force U joints $35
Strut tower brace for TTA (new never installed) $ 45
Felpro valve cover gaskets (new) $5
OEM upper and lower rad hoses and outlet hoses (used) $15
OEM turbo feed/return oil lines (used) $10
One extra pace car door decal (reproduction) $15
OEM oil cap $25
Ignition coil (used) $40
Electronic ratio adapter (used to make spedo correct if you have a diff rear end gear ratio) $50
Coolant bottle and foil insulator (used, fair condition) $35
2 rear seat leather cushions (1 in good shape, 1 is faded) $50
6 brand new NGK spark plugs $15
Taylor spark plug wire set (used good condition) $20
Stock aftermarket fuel psi regulator $5
8 sets of factory size pushrods $10 each
OEM adjustable wastegate $85
If anything is of interest to you make a REASONABLE offer. Some items I am firm on the price. Or offer on everything and take it all! I do have pictures of the items just PM your email and I will send them to you.
Is the electronic ratio adapter adjustable or is it ratio specific? Do you know if it can correct a speedo error?
The adaptor is adjustable and has different manual tabs to adjust to give you the correct spedo reading. It is meant to give you accurate odo and spedo readings if you have a different gear ratio or oversized wheels/tires.
