Well i am trying to fix a problem for a good friend of mine..
he has an 87 t type that is all stock with 88k on it
we put in a new 02 last fall and welded up the headers and did new plugs and wires shortly before that
but not the car runs like garbage once it gets pretty hot... if you touch the gas at all it bogs bad and sputters and misses...
when it is cold or warming up, it runs like a champ with no problems other than a slight hesitation right off of idle
i have tried the stock chip aswell as a reds 93 chip both have not improved the condition
what else could it be?
would a bad MAF or coil pack only act up once hot?
the car has no gauges at all and the boost gauge i think is pretty far off in accuracy... as well as the useless stock tach
just wondering if anyone has any ideas on what to do, i am going to do a basic spring cleaning and reset the TPS and IAC sensors and even the cam sensor,
what else should i check??
thanks in advance
thanks in advance
