I plan to turn the wick up and shoot for a 10 sec pass but I gotta correct this issue first.
I have the car up on stands right now...I started taking things off to look for an issue....I pulled the rear sway bar off and inspected all my bolts on the control arms for tightness. Not finding anything loose I started taking the lower control arms off. ( I have SS fully boxed arms) When doing this I noticed the 2 brackets that the lower control arm bolts to just off the axel would move......the bolt is tight but the two plates move back and fourth. I took the plates off and they show lots of wear from the movement.
My question is....should there be movement her for suspension travel or is this my problem? If its not supposed to move how do I correct it? As I said the bolts were tight but its obvious it does move.
I pulled the lower control arms out o inspect the bushings also.....one of the bushings was froze up....I got it out and cleaned and lubed it but no singes of damage.
I am going to keep digging.....
Suggestions welcome.
