8 87we410877 Well-Known Member Joined Apr 5, 2005 Apr 13, 2019 #1 Found a rear window finally. Will an 86 Monte fit into my 87 t type? Is it the same window?
wdxwrx Member Joined May 3, 2013 Apr 14, 2019 #2 Yes. I believe all G-Body cars share the same glass. Except the quarter windows, which are unique to the division of manufacture.
H HI85WH1 Shhh... I've got a Secret Joined Oct 30, 2001 Apr 14, 2019 #3 Rear window is the same. Rear quarter glass is specific to each model.
H HI85WH1 Shhh... I've got a Secret Joined Oct 30, 2001 Apr 14, 2019 #5 Let me add that the exception is the defroster/non defroster... they interchange but of course will not work without the related components.
8 87we410877 Well-Known Member Joined Apr 5, 2005 Apr 15, 2019 #6 Do all model defrost lines go around the 3rd brake like as on the regals though?
wdxwrx Member Joined May 3, 2013 Apr 15, 2019 #7 Yes. On all '86 and newer G-body cars. '85 and older cars the lines go straight across.
8 87we410877 Well-Known Member Joined Apr 5, 2005 Apr 16, 2019 #8 wdxwrx said: Yes. On all '86 and newer G-body cars. '85 and older cars the lines go straight across. Click to expand... Ahhhhhhh. I see. Thank You!
