how rich do his chips run? i have one installed on my car and now people notice a little bit of black smoke at WOT when they are behind me. hope its just the chip causing it.
Reds chips are closed loop. I think he turns the EGR off in race chips though.
I passed Maryland emissions with Reds 93 chip. I just lowered the fuel pressure to 38# and disconnected the waste gate rod (so it would not build any boost).
Make sure the EGR system is working and the car is in good tune. Put in whatever closed loop street chip you have and give that a try. If you don't have one get someone who burns chips to make you an emmision chip.
Passed AZ emissions with a 100 Reds chip, EGR blocked, 55lbs injectors, and a 45a turbo. I ran through with a know good cat , 5 gals of 91oct, 1qt denatured alcohol, and static fuel pressure of 32lbs.
