usetaboost
SAY CAR RAMROD!!
- May 4, 2005
Should be interesting. That right there would tell you how shitty they actually are. Couldn't imagine them much worse than the hot air intakes
Tight Tight, spark plug gap @ .022 from the last time I put them in. They are non-projected tip NGKR5673-7What's your plug gap set at?
Please send me an email about the 2 step and how it works Adam. I'm looking for every advantage I can get here.Fixed everything and the tach is good now(cut the brown loop!). There were no issues with the revs before just not seeing it right because the tach, I've been running the engine up to 6k rpm not knowing before.
2 step is hooked up and works good in conjuntion with the trans brake. Set at 3500 results in nearly 10psi to launch with and is already too much just for 275/60r15 street tires. I like the 2 step it's smooth and sound good. Perfect full auto shifts at 5200 and I set the rev limiter to 5700 since I can easily see it revs to 6k with the tach working rite. I'll get a video recorded soon, I bumped the boost up to 22psi since I feel safer now with boost proportional retard, probably won"t go any more with just 93 fuel.
