Replacing heated O2 with sensor single wire
smokingunz
My heated O2 sensor finally died, I want to go back to denso single wire. I didn't install the heated setup, wondering how much I have to change or rewire or whatever. Can I just plug in the singe wire and leave the other connector off??
Sent from my XT1254 using Tapatalk
Just plug the single wire in when you unplug the wire for the heated one. 10 sec job. Leaving the heated one where it is will not hurt anything however your car may not run quite as well without the heated setup
Thanks! So the other plug is just for the heater sensor? I can certainly my replace the heated sensor if this isn't as good
