I have broken a few stock rocker bars.....I just got a set of solid bars and the RJC braces from a board member. I also picked up a set of the rocker bar studs from TA.
I plan to chase the threads in the rocker towers and run the studs down with some blue locktite.
My question is to those who are running this setup......do you run the same amount of tq on the nuts as you would the stock bolts or do you go a little more being that is studded.
If so what are you torquing the nuts to?
