This is the only rod that the bearing doesn't sit flush on the ends. Could the rod have been not resized correctly? Seems like everytime I make time to put my motor together, something is wrong.
Sorry to hear that. Have or can you swap that one bearing into another rod to see if it fits the same in a different rod? That would eliminate the rod theory and check for bearing crush after installing it and checking clearance.The rods were resized a long time ago. Long story short, I had a rod bearing fail, but not spin. I had another shop check everything out and was told good to go. I even checked. The sizes are all good. Looks like the first guy botched cutting the rod and cap. I'm almost positive this rod is the one that the bearing failed in too. Always something.
That's good news, gteatr6!I happened to have a few lying around from my motor that I broke the crank in. The rod was to size too.
Your rod bore was honed off center on that rod. The ID might be correct, but it moves your piston down in the bore. It looks like a good 1/16th", so think about how much it changes your compression on that cylinder! I got a set that was done that way also. A screw up at the machine shop. Probably an inexperienced machinist. Had to scrap a couple rods.
Now that could spoil a low budget build!
one more thing I forgot to add, in order to get the proper bearing crush you need between .0006 and .0015 of the bearing sticking above the surface of the rod or block. best way to check this that I have found is to push down on bearing to where its flush with surface and use a dial caliper to see how much is stcking up. but remember six ten thousanths on the bearing would double that if measuring from one side. might ask some of the gurus on this site If they have another way of doing it, this is how ive always done it and haven't had any probs.
