shumpertdavid
- May 13, 2004
I have the following Parts for Sale or Trade:
Rollmaster 9 keyway Double Roller Timing Set New in Box P/N CS7010 Buick V-6 Even Fire W\Integral Distributor Drive
$110.00 Shipped
Lunati Hydraulic Flat Tappet Cam New in Box P/N 00251 Grind Number BM-II Buick V-6 Even Fire W\Integral Distributor Drive Lift at valve .496 In\Ex, Duration at .050" 224 degrees, adv Duration 290 degrees, Lobe Separation 112
$80.00 Shipped
Lunati Valve Springs New, they are installed on heads but heads haven't been out of bags from machine shop. P/N 73943
$35.00 Shipped
Elgin Hydraulic Flat Tappet Cam New in Box P/N E-914-P Buick V-6 Even Fire W\Integral Distributor Drive Lift at valve .496 In\Ex, Duration at .050" 224 degrees, adv Duration 290 degrees, Lobe Separation 112
$65 Shipped
Elgin Hyraulic Flat Tappet Lifters Set of 12 New in Box P/N HL-1969S
$30 Shipped
Seimens Deka 36lb High Impedance Pencil Style Injectors P/N 9267 Set of 8, Low Miles. They have Bosch EV1 style plugins.
$190 Shipped
All Parts are Best Offer, I need to sell these to continue Funding my new Motor build. I need the following parts also:
14 Bolt baffled Turbo Oil Pan
Timing Chain Cover for 14 bolt block
Double Roller Timing Chain Set for Oddfire setup
Odd Fire Camshaft Snout Parts (I'm Running Even fire roller cam with odd fire snout)
$110.00 Shipped
$80.00 Shipped
$35.00 Shipped
$65 Shipped
$30 Shipped
$190 Shipped
