Rpm surge
ALblackT
After I stop, and put my car in park, or neutral, my rpm shoots way up. Almost 2 grand. After a few seconds it normalizes. Is this normal? If not, anyone know what might be causing it. Thanks
This chip. I'm not sure which sm data you need, and from when. I know the o2 is all over the place most of the time. Except WOT. It's around 800 , or a little less.
I know when the car is idling correctly and I pat the brake, it idled up high. If I remember right, that means vacuum leak somewhere?
All the scanmaster data from idle.
And FWIW in closed loop the O2 is supposed to jump back and forth.
