28" tire
Carlos, I run the 28x10.5 MT's and use an 8" Centerline wheel w/4" BS. I also use a 3/16" spacer. It's a tite fit on the inside and see some scuff marks on the inner well. I think if I had it to do over, I'd use the 3.75" BS and be a bit better off.
There are no mods done to the frame or body.
This combo will not work if the car has been lowered more than about 1.5". [Mine is lowered on all 4 corners by 1.5", using EDELBROCK Sport springs.]
Also: It's important to be sure the body is straight on the frame and that's best done by replacing the body mounts and doing some measuring before you bolt it back down. I use the PST kit that includes the GNX bushings. Best $150 I've spent on a restoration to original specs.
I also use the lower ft end braces off of a 442 and a homemade trunk brace, HAL Stocker Stars shocks and my CODY suspension pieces. Car 60's in the mid to low 1.40's w/ the slicks at 12 psi.
HTH,
![Cool :cool: :cool:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
