scan master looses reading
TurboBusa
huh??
ok i have the scan master 2.1. the thing works great but when i give the car a little throttle almost halfway pedal and hold it there the scanmaster readings disappear and the 2.1 flashes fast. if you give it more thorttle past half it it comes back again and gives readings. i checked all connections and made sure ground is good. everything is the way it should be and connected good. it works fine till you get to almost half throttle and hold it at that position. any ideas?
