M melrob94 Member Joined Dec 14, 2006 Dec 22, 2008 #1 How do these numbers look at idle and warm? RPM 825 O2 703 TPS .45 LV8 40 CTS 149 IAC 26 BLM 126 INT 128 MAT 52 Volts 13.6 O2 counts 0 Idling open loop Rich Thanks. Rob.
T TurboBuRick Moderator Staff member Joined Feb 18, 2006 Dec 23, 2008 #3 X2 They look good! Just a tad high on the tps but nothing to cause real concern. Rick
B bmackinnon Active Member Joined Feb 24, 2005 Dec 24, 2008 #4 I'd venture to say PERFECT!! Now, how do they look WOT? :biggrin:
K karst#9 Member Joined Feb 24, 2003 Dec 24, 2008 #5 melrob94 said: How do these numbers look at idle and warm? RPM 825 O2 703 TPS .45 LV8 40 CTS 149 IAC 26 BLM 126 INT 128 MAT 52 Volts 13.6 O2 counts 0 Idling open loop Rich Thanks. Rob. Click to expand... What is MAT 52? Thats not MAL 52, calpack error is it? what are you using for a scan tool
B bmackinnon Active Member Joined Feb 24, 2005 Dec 25, 2008 #6 karst#9 said: What is MAT 52? Thats not MAL 52, calpack error is it? what are you using for a scan tool Click to expand... MAT = manifold air temp I think on SM (same as IAT (inlet))... cool day out I would guess... :wink:
Chuck Leeper Toxic old bastard Staff member Joined May 28, 2001 Dec 25, 2008 #7 "Idling open loop Rich"... Could be at the 149* water temp, the program is still adding cold start fuel?? I would not consider 149* to be "warmed up"...
M melrob94 Member Joined Dec 14, 2006 Dec 25, 2008 #8 Thanks for the comments. I am using Turbo Link. It was a cool day, the car was still warming up. It does say MAT 52.
