Hey guys, just got tags for the buick and went out for a spin today. Noticed that the scan master doesnt turn on anymore. Its wired into the same port under the dash for the ECU signal. Its plugged directly into the fuse panel for the 12v battery port at the bottom of the fuse panel.
Subsequently, the transmissions TQ lockup manual Switch that a buddy of mine (Steve V) had wired in no longer works as well. Car drives and boosts fine but the torque convertor doesnt lock up and the scanmaster doest operate. Strange as it is, i remember they were working fine before i pulled the car in the garage for paint. (i never took out the dash though)
Does anyone know where i can start to look? The manual lockup switch seems to be going into the fuse panel as well, and just to see if it wasnt the switch that was bad i went for a drive and bridged both connections manually...but nothing locked up...
Im totally lost with this and your help and suggestions to look and start would be helpful.
