Eric Stage I
TurboTweak Guy
- May 25, 2001
Sent you an email. I'm starting to question the injectors now, since that's when the problems started. I'm sending you another set.
One thing I just noticed...when I hit the throttle...the fuel press drops, when I let off the throttle fuel press goes right back up to 38-40 psi. Additionally, this only happens when the engine is warmed-up.
You probably did this already, but did you check for vacuum leaks? On your fuel gauge, does the needle move pretty smoothly, or does it dance around any more than your used to? Also how long does the car hold it fuel pressure after you shut it off?
A bad TPS can turn into an expensive guessing game.
Nick can you help me work on my car sometime, you really seem like you know what your doing!Hello, I've just installed a few items on my 87GN. TT chip & 42# inj, frnt mt intercooler, cold air intake, reworked tb & plenum, new tps. Engine stumbles pretty bad while trying to accel in park. Thanks in advance for any assistance. Here are my SM readings: mv 394 AF09 L8 43 bAt 13.9 Int 128 bL 122 MPH 00 CLt 146 AtS 88 r 775-850 (bounces) tPS .42 IAC 10 cc 09-233 (bounces all over). Thanks again!!! Nick Eustaquio
