forcefed3.8's
Buckeye Bullet
- May 26, 2002
I made 2 runs with the sd2 chip in a friend's car he other night. After some fueling and AFR target adjustment, and setting high map timing to 18, made a good clean pass. Came back checked over the log, and timing showed 25deg, where it should have been 18. This is at 28lbs boost. Is the timing accurate on the powerlogger, what would cause the timing to stay so high?
