I kept stretching the Kelley belt that measured at 63.5 inches long, (sorry I do not remember the part #) this also was destroying my tension pulley to boot. So today I replaced the tension pulley with a replacment pulley part Dayco # 89003 and the belt with Gates K060620. At first it did touch the I/C d. side mount but after the engine idled for a few minutes with the A/C (and bracket out of the way) on it stretched and became a "good" fit having the same distance from the A/C puuley as the Kelley belt before the stretching occurred. All in all I don't think this is the only solution to the "we no longer make the proper size belt" problem but it was the one I came up with. The belt is close to the I/C bracket prolly within 1/2 inch but I'm happy with this out come so far. The last Kelley serpintine belt was only 1.5 weeks old with use of A/C and was shot. I just could not see replacing it every week even though they are $10 a pop.
I hope this helps anyone that has had this problem..........
