shakedown passes on new motor
turbocody
GOT BOOST!
made 2 shake down passes right off the trailer w/ the 275/60 drag
radials. 22.5 pounds of boost w/ 20* timing in all gears.
1) 1.58 60'(3psi launch)feathering throttle.
6.79 @ 103.02 mph
2) 1.53 60'(5psi launch)feathering throttle.
6.76 @ 102.22 mph
i hot lapped the 2nd run so the car was a little hot.
not to bad with a base tune from Cal Hartline and little timing. the
car pulls very good on the big end, i was short shifting at 6k. i think
i'll keep it tuned back till the engine loosens up more and get a roll
cage in the car, then the fun can start.
also, some buddies of mine watched the wheels come off the ground
6inches right before the 60' ended and carried them for 4ft of so. i
think the power is coming on strong for it to do that. i still do not
believe them, but they said it happened both runs. video camera will be
present next outing.
Your off to a good start, Cody! If you want, email me the logs and I'll see what we can do.
well, it would be hard to bring it. I did not prepare enough ahead of time. ohh well, next yr i should come.
