forcefed3.8's
Buckeye Bullet
- May 26, 2002
I have a set of Howards 1.437" diameter springs I used with a hydraulic roller on GN1's. They are rated at 175lbs@1.75 400lbs@1.15 with Comp Cams #731-12 titanium retainers. The retainers are new, just installed on the heads, then went solid and needed new springs, and +.100 retainers, springs are 2 seasons old $225 shipped
1 set of Comp Cams 941-12 roller valve springs very little use will work on iron or aluminum heads $75 shipped
109 shortblock, has around 800 miles on it, .030 over with speed pro forged pistons, 20/20 crank, ARP studs in mains, and I think ARP bolts in the rods. No cam, lifters, front cover $800 local pick up only
I also have many trim and interior pieces, also BQ and BRF cores all for local pick up, and engine assy brackets, pulleys, etc. PM or post with needs.
