So I have read a few threads regarding the head stud that requires an extra washer for better clamping. Needless to say I came across the thread after I had built my engine. My engine has been together for a few years now and I have not had any issues from it..
I just installed a set of solid rocker shafts and RJC braces and while the covers were off I took a second look at the stud and started to think.....should I pull the nuts off, add a washer and re torque????
Well I have had no issues but I also have not run the car past 17psi so it has not seen crazy cylinder pressure.... I ran the car earlier this year at 17 psi with no issues zero kr to mid ll's.
I up graded my rocker bars because I am going to try and hit the track next month and shoot for a 10 sec pass.....I figure I am gonna need 23-25 psi to do it.
With that said....should I pop that nut off add a washer and roll or should I leave it alone?
Has anyone installed studs and not added a washer and lifted the head due to this issue?
I am scratching my head here.....opinions please
