I think of it as simple anyway.
Still working on suspension mods to get the 60ft's down, but here's what can be had:
Champion mild ported GN1's - 7-8 year old castings, but not the original castings.
Stock crank, rods, and TRW pistons
212-212 comp cams flat tappet cam - yes guys still use flat tappets
Precision Plenum with RJC plate - I used to not be a believer
Precision 6765 dbb water cooled cast wheeled turbo
Extreme automatics stage 2 trans shifting at 5500 - Thanks Lonnie
Extreme automatics V1 intercooler
PTC 9.5 nl converter - Thanks Dusty
Fast XFI - with tuning tips from Cal Hartline
275 pro drag radials
This is after technically my 4th track outing - all traction limited - hopefully will be corrected over the next couple of weekends.
Boost was about 23 psi on these runs with just a touch over at times. Also boost limited - needing more wastegate spring.
Unfortunately, I blew the tires off in the race pass and didn't get my point for team buick.
Enjoy
Enjoy
