smog junk
turbomontecarlo
im faster then you!
i blew the head gasket a while ago and now i am finally rebuilding it. thinking taking off all the smog junk. any advice on if i should or shouldnt. pros v cons? i dont have a cat so i pay to pass it. so thats not an issue
i would leave it on... californias got some strict emissons laws, and suprise emessons testing.
Do you mean the smog pump or all emissions stuff? Without a converter, there is no need for the smog pump. It's job was to help the convertor function properly. You can remove the pump, valves and piping.
This will be helpful:
THE Smog Pump Thread - TurboBuicks.com
In general, there is no performance benefit to removing emissions equipment.
i think on car science they said for every 100 pounds you lose you gain .01 second i may be wrong on the exact number. the only bad thing is the states dont want you to revove it. the weigth saving is a postive.
