I pulled the motor because I wanna do some work on the front end also Lighten it up a little bit more .Just makes it easier doing the heads alsoDid you pull the motor or take the heads off in the car. You made over 800 rwhp did you hurt the motor, it seems strange to port the heads now. Are you going with same cam and turbo?
Its a street car [emoji12] ok some times a street car lol the heads now flow in the mid 264 range and the mid flow is awesome .a fully cnc port job on the ta se head flows ave 1126 mine are 1145 Because the overall flow is awesome .he did a awesome job hand porting. The roof was raised also.
Sent from my SM-G955U using Tapatalk[/QUOTE)
What size did the runners end up being?
Same measurements as a fill pro 1200 Except raised the roof 2inch 200 tall So a completely different gasket will be neededDamn fat fingers.
He is still working on the heads He will know in the end .I meant runner volume as in cc's
Yeah there big lolBad ass bro I am in the middle of switch from my ported TA heads to stage heads . The design of the stage heads are just killer and the ports will swallow my TAs lol View attachment 309281
