Some ques. on conversion
nboost
going to a vacuum brake setup like many of you that have had Power Masters fail. What all is involved as far as hooking it up? just a bolt in procedure and bleed brakes? do i need to disconnect anything that may leed to the ECM? Thanks
vac conv
Just a bolt on. Try to find a NA pedal in a junkyard(mine cost $5.00). If you follow gnttype.org directions dont take the pivot bolt out of the pedal while your under the dash. Take the pedal out first. 4 bolts I think. If your brake light wont go off in the dash, bleed, bleed , bleed. Nothing to worry about with the ECM
