Southeast Turbo Performance announces their new fabrication facility is in full production of brand new internally wastegated 3" Stainless Steel Downpipes!!!! Over 50 pipes already installed and currently running on Turbo Regals around the country, don't wait another day.
As many of you already know, finding new downpipes for the Grand National has become extremely hard to find recently. Well, Southeast Turbo has gone into full production starting with internally wastegated 3" downpipes and will be out soon with their external gated downpipes. Look for our 3.5" downpipes this fall.
Our downpipes feature 304 Stainless Steel parts. We tig weld the entire assembly here at our fab shop. Take special note of the weld bead around the pipe/flange joint!
The pipe is mandrel bent and is tigged to the 3/4" turbo flange by hand.
All the internal moving parts are made with 304 stainless steel and feature a full 1.375" wastegate puck!! These parts will not rust and stick later.
The 3/4" turbo exhaust flange is laser cut and made of grade 50 steel. The steel is painted with a gray 1800 degree high temperature paint to prevent ugly rust.
Our 3" cutouts are made again with 304 stainless steel. We have them laser cut to provide an incredibly exact fit with no internal overlap. Just check out the incredible weld bead! The cutout's are made to slip over the downpipe and bolt onto your four bolt cat-back exhaust system. The dump tube is secured with stainless hardware and the end cap uses a graphite gasket to eliminate any exhaust fumes from entering the car.
The downpipe package includes all stainless steel hardware for years of trouble free use!
At $450.00 they are flying off the shelf!!
Please specify what type of header you will be using at the time of purchase.
