BillyRValentine
Capricorn
- Nov 4, 2005
1987 Hardtop GN body for sale. It has a clear title, NO RUST and no body damage. The following parts are included in this sale -
1987 Hardtop GN w/ -
8.5 in Pro-series Auburn Unit 3.73 gears (Factory 3.42 come with it as well.)
Factory Headers are great shape no cracks
Factory crossover
Factory Intercooler
2 Roller Cams (One is a 206 Comp and the other is a 218(?) Ruggles)
Roller lifters
Chrome molly Comp pushrods
Hi output Alt. kit
Volt Booster
Knock sensor
Coil pack bracket
2 sets of 4.1 pistons (1 set of Ross aluminum and a set of cast.)
2 factory turbos
2 wastegates
Phenolic spacer
2 timing chains
Set of red stripe injectors
Flexplate
2 blocks
2 sets of rods
2 lower intakes
2 upper intakes (One bored to 62-mm already just needs to finish blending.)
2 Throttle bodies
Radiator
Factory fan
Fuel rail
Accufab regulator
All fuel lines are as they should be.
Walboro 340 fuel pump.
LS1 Brake conversion comes with it but stock brakes are on the car now.
Manual booster will be included but car has stock unit on it now.
Set of stock heads (Just out of the machine shop.)
Set of ARP head bolts
Fuel Pressure Gauge
Starter
All the wiring and TV cable are still in the car.
Drive shaft
Crossmember still in vehicle
Autometer Comp. elec gauges with gauge pods
B&M Megashifter mounted in console.
1 set of acces. brackets
Car has 15x10-in. ProStars with 295/50-15 (Back) and 15x5-in. 185/?-15 (Front)
Comp. Eng. 90/10 and 50/50 shocks as well as set of KYBs
200R4 Tranny (Needs Building)
$4900.00 takes everything. Now for the fun part - I WILL NOT SEPERATE ANYTHING!!! I only want to sell it as a package deal. Please do not PM me asking if I will take $4000.00 for everything either as anyone who has read this can see that the value of this deal is worth more than the asking price. Thank you for your time.
Jim C.
334-538-5868
Factory crossover
Factory Intercooler
Roller lifters
Hi output Alt. kit
Volt Booster
Knock sensor
Coil pack bracket
2 factory turbos
2 wastegates
Phenolic spacer
2 timing chains
Flexplate
2 blocks
2 sets of rods
2 lower intakes
2 Throttle bodies
Radiator
Factory fan
Fuel rail
Accufab regulator
Fuel Pressure Gauge
Starter
Drive shaft
Jim C.
334-538-5868
