So i have a spare engine I need to use. Was supposed to be low mileage 87 gn motor. Who knows what condition its in... Definitely stock 87 GN engine.
I did a leak down test, and seems to hold 100% pressure. Moved on to the compression test, and got range of 155psi to 165psi with 160psi average.
Not sure where to go next with this.. thinking check oil pressure next...
1. have some original oil from the old filter, think i should send it out for the test? I heard blackstone is decent, any suggestions appreciated
2. replace timing chain, oil pump?
3. replace all the gaskets?
4. replace the head gaskets?
any suggestions or advice appreciated...
