B blackbird skunk works Joined Feb 19, 2002 May 23, 2004 #1 what are the symptoms of a spun bearing??
S S2V6RACER Banned Joined May 25, 2001 May 23, 2004 #2 Typically knocking, maybe only at higher than idle RPM. Low oil pressure also. Your oil should indicate metal. Cut open your filter too.
B blackbird skunk works Joined Feb 19, 2002 May 23, 2004 #3 Doh!! thanks, what would cause the oil to leak out of the engine??
T TurboShane WE4 Super Freak Joined May 25, 2001 May 23, 2004 #4 Worn out rear main seal. Witch is cause by crank shaft play back and forth.
B blackbird skunk works Joined Feb 19, 2002 May 24, 2004 #5 FUDGE ive got all those symptoms!! im looking to get an ATK remaned engine but i need a place close by so i can order it and have them install it. i would love to try it myself but im workin two jobs and volunteering on the side so im screwed out of time.
