My engine is junk.
I’ll buy that junk from you.
Base fuel pressure and whos chip?93, 60lbs. Stock ecm
Yes I have. And read this that the so called stand up guy you all praise. I’ve been dealing with this since 2017.
What would you do. He flew right away to Charlie’s place to fix his mess.
Hey TurboTGuy What do you think about what you see in this video?updated picture
and a bad rap on passenger side. rockers need adjustment
Do you think that if he hasn't added oil to his engine that this is OK?
And you can here it rapping hard. My dad is 81 and can here it across the street.Hey TurboTGuy What do you think about what you see in this video?
Regardless of the leakdown,I think the finish and shape of the cylinder walls is the cause.If the leakdown test checks good, what would you say could be the cause?
There's no doubt that combustion gasses are getting into the crankcase. The reason I say cylinder walls is because the shape and finish of the walls determines the ring seal. You can't blame it on the rings.Yeah when I showed Steve the video first think he said was rings and pistons why didn’t he do it in the first place. I don’t get it.
