1987 GN Stage II best time to date is 9.40 at 142.7. Current Chassie Cert till 02/07 for 8.50 and slower. Motor freshened 6 passes ago, Tranny (T400) freshened 4 passes ago, New Neil Chance Converter. Fiber glass hood and front bumper, all the rest is stock steel. A list of items on the car are:
Heads
Gn1 Alum heads
Ported and polished and flowed by Greg Goode
Head gaskets are felpro wire lock #1007
Head bolts are ARP
Block
4.1 Stage II oncenter
bore 3.830
Steel crank 3.625 stroke stand by stand
pistons are Venolia forged
Cam is a PT&E .236/.236 @ 50 or .274/.274 @ .015 with 110 lobe centers solid roller
lifters are Crane Cam solid roller
Valves are Ferrea #GN1600 and are 2.10 and 1.70
timing chain is a double roller
oil pump is a Precision Turbo front cover hi volume pump
Blueprinted and balanced by Conley's
Bottom end all ARP bolts
Intake
BGC ported and polished by Conley
Plenum is BGC ported and polished by Conley's
Headers
ATR Big tube SS headers
Injectors
160#
Fuel System
Weldon 2015 pump with
two 8AN lines feeding both sides of the fuel rail
the stock fuel line is used as a return
Computer
Fel-Pro Sequential DFI
MSD Digital 7 with MSD Distrubitor and coil pak
Spark plug wires MSD 8.5 #31179
Spark plugs Autolite 103 or NGK 4554
Turbo
PT&E PT-80
Conley's down pipe and Trubonetics Racgate
Transmission
T400 built by Airabe
With t-brake
Converter
10" Neil Chance
Drive Shaft
alum by quarter master
Rear end
Mossier 35 spline axle
U.S. Gear 3.89
U.S Gear Spool
Ford Motorsport 11" Disc breaks
Mosher 9" Center Housing
Mark Williams Center Section
Metco Lower Control Arms
adjustable Bennett upper
Comp eng adjustable shocks in the rear and QA-1's adjustable in front
Springs, (new rear springs old stock front)
air bags both sides
Front Tires 205/75R/15
Rims Crager Drag Stars 15" x 5
Race Tires 10.5 X 15 M/T 29.5 tall
Rims Crager Drag Stars 10" with 4.5 back spacing
The car also has Chassie Eng wheelie bars and Strod air launch chut. The body is stright and paint is good, there are a few scratches. Int is good with stock seats and new headliner just installed.
Asking price is $25,000 with much more invested.
Heads
Gn1 Alum heads
Head bolts are ARP
Block
bore 3.830
Intake
Headers
Injectors
160#
Fuel System
Computer
Turbo
PT&E PT-80
Transmission
With t-brake
Converter
10" Neil Chance
Drive Shaft
Rear end
U.S. Gear 3.89
U.S Gear Spool
air bags both sides
