Taylor04 Member Joined Feb 12, 2008 Oct 17, 2010 #1 What AN-6 fitting are you guys running for the steering pump? I know it is o-ringed just like the steering box and hydroboost fittings. I thought for some reason it was a special short threaded fitting. Do you use the same 16mm or 18mm fitting?
Taylor04 Member Joined Feb 12, 2008 Oct 18, 2010 #2 no special fitting Power steering pump uses same style metric o-ring fitting as the steering box and hydroboost. AN6 TO 16MM X 1.5 I.F. MALE o-ring Speedway Motors part# 617-4806 AN6 TO 18MM X 1.5 I.F. MALE o-ring Speedway Motors part# 617-4808
