9 99Formula Senior Member Joined Aug 8, 2002 Dec 14, 2002 #1 I replaced the unit with a new one. Unfortunately, my climate control still only runs when set on the maximum fan speed, and the A/C switch doesn't work. Is there something in there I need to clean out? Any other advice? Thanks, Peter
G GNVenom Well-Known Member Joined Jan 6, 2002 Dec 14, 2002 #2 I'd bet your problem is in the module under the hood. Here are some images: http://www.casperselectronics.com/images/blower-regulator1.jpg http://www.casperselectronics.com/images/blower-regulator5.jpg http://www.casperselectronics.com/images/blower-regulator2.jpg The large transistor shown is usually the problem. It can be replaced and the new part soldered into the PC board. Hope this helps, John Spina http://www.casperselectronics.com December Sale items on website.
9 99Formula Senior Member Joined Aug 8, 2002 Dec 14, 2002 #3 Cool, thanks for the info guys. Is that transistor something that I should be able to pick up locally at a Radio Shack or something? Peter
