ok this is a little bit of a story, i got the car when i was 16 its mine and my dads project car, when i was 17 i didnt really have any money for the more expensive parts i needed and i was bored so i just started taking things apart (stupid i know this now, but thats how i discovered the turbo was blown) so when i put the turbo oil drain line back on, i pushed the grommet (which was in rough shape) down the intake, when i replaced the gasket, i didnt use sealant because it gave seals for the front/rear of the engine, (i didnt know anything back then, ive actually finished school, and just started my career as a mechanic) so now im 20, and after a suspected vacuum leak (stalling if not incredibly slow on throttle from a stop, low boost, high idle) i decided to do the intake properly. before i connected the oil feed line, i wanted to crank the car to make sure i had oil, which i did not so i took the adapter off to prime the pump, and it didnt work 3 times. this is why i did what i did.
