stock 109 block cheap, engine parts
BW Jones
for sale:
stock 109 block with stock main caps & oil pan & oil pick up
two cylinder walls are scored so it will need to be bored.
otherwise it's in excellent shape.
$100 or best offer
also available:
used stock GM front timing cover in excellent shape with complete stock oil pump assembly $80
used stock harmonic balancer with interrupter ring in excellent shape $65
oil slinger $15
set of 6 stock 2 dot connecting rods - best offer
big bolt & washer that fastens balancer to crank - best offer
Tinys ....... i'm right on the state line (3 hrs from indy).
:rolleyes: when i posted this thread, i had completely forgotten about a small break at the driver's side rear of the block where 1 of the 6 bolts is located for mounting to the tranny's housing ..... this does not effect the integrity of the block. it just means that only 5 of the 6 bolts can be used to mount the tranny to the engine.
please see the photos below.
