Stock tachometer not right!
opeltwinturbo
My stock 87 GN dash tachometer is screwed up. I am looking for some suggestions. With the ignition on and engine not running the stock tach reads 1,000 RPM. At idle (800 on the aftermarket tach) the stock tach reads 5,000. The stock tach goes immediately into the red zone when engine RPM is increased.
Help !!!:confused::confused:
Check and see if the two wires (one is green) with male and female plugs located behind the alternator are plugged into each other. If they are .....unplug these two wires and you tach will work... leave them unplugged....
I know this is an old thread but I just picked up a T with the same issue. Are these writes not supposed to be connected?
N6 running Nexus Project X
They are not supposed to be connected,one is the fuel pump prime wire,one is tachometer signal .
