Ok just my 2 cents worth. 87 T, this will be 2 examples, stock engine, ic,turbo, blue tops, Tin man cold air kit, adj. fp. adj. wastegate, stk. front tires, rear slicks, front sway removed, pass. r airbag, this was in 02 Buick
Race Day in Norwalk. 24# boost @ 8lb launch, 12.08 @ 110.0 1.60 short time, with OTC 4000, no knock, C16 mix, and running rich all day. Unfortunately my cam took a #3 dump on me after that. Tranny was redone b4 all this. I went with a 208-208 and new valve springs. Added atr rr swaybar, and running Reds 108 chip. I just wanted to hit 11's with stk ic turbo, ect. Cool day at track, 62degrees, 112.7 oct. removed spare, 8lb in rear airbag, 8 lb launch, no knock, 24 lbs of boost, 11.86 @ 111.98 w/1.58 and weather was getting cooler. I have learned that tuning isthe most important thing to do. Moniter is a must, or cash will fly. Since then I borrowed a F/M and TA 49, good for 11.34 @ 118.09 w/1.63, wont cut up car but maybe one day!!
