Stock Turbos
C
CamaroFreak87
Guest
what are the stock turbos for buicks? I've looked on this board but could only find stuff on the TE60, TE44, etc. is there a difference in the different years of turbos? I'm thinking about buying 2 used turbos for a "mild" TT setup on a 3rd gen Camaro 350. I wanted smaller turbos for better spool time and thought the buick turbos on a V8 would work good, and I heard that they are generally cheap and readily available. Any info or links to info is appreciated. Keywords to search for on this board or others would help, too. Thanks
Ryan
Ryan,
I believe the stock GN turbos are a tad larger than what incon used on the Mustang TT kit. If you shop the for sale part ive seen them go for 100-250 in good shape. Rebuilding them is easy.
A better place to find TT info is here:
http://www.turbomustangs.com/
Good Luck
Stock Turbo
Garret turbo is stock item compressor side a/r .60 turbine side a/r .63. They come with a bypass actuator.
Am selling one stock piece with low miles... Darth didn't like it.
