Strange electrical problems. Car dies when load is put on elect. sys.
For the second time in 3 days my car is showing strange electrical problems. Basically the idle studders, and dies, unless the flashers are turned on, then the cars revs up and idles fine. If I try and turn on the headlights, it will studder and die, I can keep an idle if I feather the gas, but when I try and push further, It just cuts out. When I tap the brakes, the parking lamps come on, even with the switch off. Is this a sign of my alternater dying? or is this a problem with the ECU? Unhooking the battery for a little while doesn't fix things, but the car jumped to life after sitting in my bosses garage during work today.
