- Jun 18, 2001
I've got a pile of stuff that'll never go back on the car I'm dragging to Bowling Green with me. I'll be there Thursday and Friday.
Full set of Original F41 Springs
Full Set of Bilstein HD6 shock absorbers
Set of Lowering springs (2-3" drop, LOW)
Set of 250lb AFCO rear springs (stock height)
Stock intercooler and shroud
Stock intercooler with 3" inlet
Stock fuel sender assembly (analog dash) with a Walbro 340 attached. Will not separate
Stock radiator fan with resistor, works perfectly
OE Chip and Injector set
OE Air filter enclosure with a couple of filters and the MAF hose
Vacuum brake booster and master cylinder
Complete Powermaster assembly (worked when removed)
I'll add to the list as I go through garage sorting stuff. I'm sure there's more.
