Hazard flashers work. Blinkers do not. All of the bulbs are good and illuminate as they should with the hazards on. I have replaced the flasher as well.
If you hold the flasher in your hand and hit the turn signal you can feel one click from the flasher and then nothing else happens. I should also note that if you are holding down the brakes and do this the one click will turn off the lights on the side that should be blinking.
Is my switch bad?
Is my switch bad?
