Well finally got the car up and running last night. Got the DIY kit installed, went to the track filled the tank up with methanol and started to do some tuning. Well soon as I hit the arm switch the power injection light comes on. I check the connections everything looks good. Sooooo I check the hobbs switch (the one recommended on Steves site.) when the arm switch is on - going in aaannnnd great, going out as well. I tried adjusting with the allen screw in and out same. Tried swapping terminals ...same. Took it apart and sprayed a shot of wd 40. Then hooked it back up this time it was staying closed so I take a run and went up to 18lbs nothing. By this time I am fuming. Get back home start to adjust it and soon as I turn the allen key switch opens. Well thats 35.00= down the drain. Bought it months ago from Summit I am sure they will not warranty it now even if it is brand new.
So which store ( would like to have it running by Saturday so no ordering) has the best quality switch for the $. Napa? Grainger?
Thanx in advance guys
Russ
Russ
