- Nov 30, 2009
When buying studs , the stud length is measured from underneath the head of the stud . So measure from the back of the rotor or back of the axle flange . Above , in the picture of my rear wheel , those are 2 1/2" studs pressed into stock axles . That is the minimum length I would use with these wheels & lugs . You don't have to remove the axles to install 2 1/2" studs , you just have to rotate the axle to get the most room ( there is one low spot ). I seated the studs with spacer then a washer & anti sieze , old steel lug nut and impact wench . They pulled right in .
The front wheel mounting thickness is .60" , & the front lugs are 1" nut height ( http://www.championbillet.com/short-shank-lug-nut-open-end/ ) .
The rear wheel mounting thickness is 1.25" ( http://www.championbillet.com/long-shank-lug-nut-open-end/ )
