Swaybar collar for anyone with an HRpartsNstuff Swaybar that had to put the axle mounting brackets in a place other than wide/narrow as possible. If somewhere in-between, it will still perform fine, but the bar will slide side to side & reduce handling performance. These collars simply bolt onto the swaybar (without taking off the car) and should be placed next to the poly brackets. These are zinc plated (gold) for rust prevention and will keep the bar from sliding side to side.
$30.00 Shipped, New never bolted on.
