No Problem! It is track tested, never locks up so far 1yr. My battery has run over 6 hrs at the track without dying.
its written in C++ Builder 5 (fairly old stuff), the UI is set up at design time, so its a pain to change it programatically.
if there is enough of a need, I can spin off a side version and make the controls a bit bigger. is it mainly the buttons that are the issue?
Bob
+1 for a tablet based version. my decision to get a new PL only laptop or tablet depends entirely on this thread. thanks for all the input so far guys
hmmmmm android.
has me thinking....
Bob
Intriguing.You can get a case for your ipad that has keys on it.
My setup is to run the powerlogger to my dedicated car computer, small passively cooled wireless atom pc about the size of a couple pack of cards stacked on each other.
I then jailbroke my ipad and have it acting as an adhoc network. you then connect your pc to that network and install some kind of remote viewing software on it (ie log me in) and onto your pad.
You then get a touchscreen pad to run anything you need to run on a pc. Its complicated but it works great and allows me to keep my ipad mounted in dash and use it only to tune, play music, navigation, games, movies etc.
If your frugal and do the work yourself you could do it for a couple hundred bucks, or if your really a nerd get a raspberry pi and do it for 30-40 bucks
no, the PLC software won't run on linux.
but there are USB drivers that could be made to work on linux. If someone wanted to write the application I can provide the communications protocols....
Bob
So do you use the lightening to USB connector to connect to the PL USB?I have a I-pad, the geek people at best buy has my PL working with my PL
