84BuickGNYorkPA
Daily Driving Buick V-6 Turbo's 1979 - Present
- Jul 5, 2005
Awesome!
Looking like your headed for the record pretty quick
Well, if we add that six hundred pound difference to it, it comes out to about a 12.20 ET lol...
I'm only kidding lol, great job Murph...
The whole physics things really changes everythingWell, if we add that six hundred pound difference to it, it comes out to about a 12.20 ET lol...
First thing is the converter and how it worked out. I left the same th400 trans and 9.5" nl PTC converter in from the old 9 sec engine setup. Figured it would tighten up and it did feel good on the street.
I had to use the data from the first run since the mph was off on the second run a little. I crossed the line at 115.4 mph and 4700. I'm on 28" drag radials that have minimal growth and 3.23 gears. Using a couple different calculators I came up with 6.7% and 5.5% slippage. Also, my rpms dropped down to 4300 on the shifts.
So thats great slippage for a 9.5" nl that wasn't bought for this purpose. And using the 3.23s that were already in my car we thought was going to work out well to keep the rpms down.
So how to relate this to other typical stock setups that have worked well? First, I'd say that my coupling rpm may be a little high. A stock restalled D5 may drop to the bottom 4000s on a shift. So I could be leaving some on the table there if I'm above peak torque. Second, I'd say a locked D5 running on 26" tires or even 27" is a good stock setup. A locked D5 with 0% slippage on 26" tires would need around 4860rpm to run 110mph, a typical good stock engine pass. 115.4mph would have needed 5090rpm. 26" slicks that grow to 27" or 27" drag radials would need 4680 @110 and 4900@115.
So to put in perspective, I'm only turning the same rpm at 115mph on my 9.5" nl converter that a typical stock setup would do with a lockup converter on 27" tires at 110mph.
Ideally, I should switch to a tighter 9.5" converter as I'm leaving some performance on the table. But I can still go almost 120mph at 4900rpm even if my slippage goes up to 8% so I should be ok.
I don't know... once I find the limit then there are probably a few things to test out to see if it makes any difference. And I'm on pump gas and alky too. Maybe try out E85 or different fuel. I think the turbo will be the limiting factor though.
And if I upgrade the turbo then the engine will probably become the limiting factor. Upgrading the cam and even a minimal port on the heads will probably make a big difference. It would be cool to see how far I can push a stock engine on a bigger turbo though and probably will be the next step down the road, but could be a while....
As far as your statement about the exhaust wheel being the limiting factor, not a turbo expert but that seems to be the case. From what I understand even though the same .63 Garrett Housing is used on other turbos all the turbine wheels are larger than the stock one. So even when you upgrade to a TA49 the exhaust housing needs to be machined out to fit a bigger wheel. The T31 turbine wheels like on the TA49 also have a different pitch. So they are all different wheels in the same housing.
