9 99Formula Senior Member Joined Aug 8, 2002 Sep 3, 2002 #1 What are each of the 5 separate ports of the vacuum block for? I've been searching for info and all I've learned is the 5th port (big one) goes to the PCV valve. Any help is appreciated. Peter
Z zam70 ->ROGUE Joined Aug 6, 2001 Sep 3, 2002 #2 PCV fuel regualor boost gauge EGR Vapor purge canister I THINK...pulling them off the top of my head....
9 99Formula Senior Member Joined Aug 8, 2002 Sep 3, 2002 #3 Thanks a bunch! Are you sure the 4th one back is the fuel regulator port? It runs all the way across to the passenger fender. What is it plugged into over there? Peter
Z zam70 ->ROGUE Joined Aug 6, 2001 Sep 3, 2002 #4 The one that goes to the passenger fender is for the boost gauge.
