Teflon tape on temp sensor?
OKTurbo
I'm finally getting around to installing the VDO coolant temp and oil pressure gauges I've had laying around for months.
I just finished installing the temp sensor using a brass Tee and a nipple so I could still use the factory sensor. Out of habit, I put teflon tape on all the joints, but I'm now wondering if this is a good idea ...if the sensor needs to use the fittings as a ground to the block. (it's a one-wire sensor)
So....what has everyone done? Teflon tape or No tape...
I'd really rather not have to worry about leaks, but I do want the gauge to work.
John
They make a teflon thread sealant in a tube. I know both Loctite and Permatex make it. It won't stop you from making a good ground, but will seal up your fittings.
Tarey D.
Thanks for the help guys...
I'll pick up some permatex/loctite sealer and take the teflon tape off.
John
I used Permatex thread sealer on mine, the VDO matches what the ECM says so it must be close.
